  F40 swap question.
F40 swap question. by rennoc442
Started on: 01-18-2015 10:11 AM
Replies: 5 (298 views)
Last post by: rennoc442 on 01-19-2015 12:10 AM
rennoc442
Report this Post01-18-2015 10:11 AM Click Here to See the Profile for rennoc442Send a Private Message to rennoc442Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys need some help. I was told that to fit a f40 behind a 3800sc you need to go with the rwd flywheel and spec has a clutch for that setup. Question is do I need to have the flywheel machined down like I would for a getrag swap or can I leave it stock? What about balancing? The engine is 2002.
FIEROFLYER
Total ratings: 180
Report this Post01-18-2015 11:49 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Leave flywheel stock thickness use the F40 SPEC clutch and also use a .25 HTOB spacer
DARN Cars now open with
rennoc442
Report this Post01-18-2015 12:21 PM Click Here to See the Profile for rennoc442Send a Private Message to rennoc442Edit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome! Now do I need to get it balanced?
FIEROFLYER
Total ratings: 180
Report this Post01-18-2015 02:12 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
I would as it is now balanced for the 3800NA not the SC engine
mkman
Report this Post01-18-2015 07:57 PM Click Here to See the Profile for mkmanSend a Private Message to mkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Forum member fierorog sells flywheels balanced for this swap. I am using his flywheel with a spec stage 3+ kit (spec part # SC883F-4). The spec kit comes with the clutch disk, pressure plate, and the spacer for the htob.
rennoc442
Report this Post01-19-2015 12:10 AM Click Here to See the Profile for rennoc442Send a Private Message to rennoc442Edit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome guys I appreciate the help. I plan on starting a build thread soon, I would love to document this build and see how much it costs me!
mkman, do you have any pics of your swap? Love seeing pics of 3800sc/f40 swaps.
