  Volvo 240 calipers
Volvo 240 calipers by cmechmann
Started on: 01-17-2015 06:49 PM
Replies: 4 (284 views)
Last post by: cmechmann on 01-17-2015 11:33 PM
cmechmann
Report this Post01-17-2015 06:49 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
I understand that this leads to the brake balance issue that comes to be when changing calipers and the hydralics will need to be addressed.
I had been bouncing around some of the British sites. Seems there are many who are looking for Fiero/Chevette front spindles.
By what I am reading the spindles were used for Fiero/Chevette/world Chevette/Imark Gemini, Scimitar and some of the Lotus. The biggest differences are the rotor behind hub design and threaded or not threaded for calipers. There is a later Isuzu rear wheel drive that used them also, Impulse. The Scimitar even used similar upper and lower control arms as the Chevette except the upper had a reinforcement built on them.
Apparently, They are using 80s 240 front calipers, for vented rotors. Carton rotors. Bolted on the Chevette spindles.
By what I had read/seen the biggest issues were the rotor offset, light mods to calipers and using a tee in the brake line for the dual hose calipers.
Now this was with using the Japan/Euro type hubs with the rotor bolted to the back of the hub. With the caliper bolted to the back of the spindle.
If there is a rotor with a deep enough offset, it seems that this could also be done on our cars, with caliper bolted to the back of the spindle.
Has anyone looked into this before? These calipers are cheap and work well.
dobey
Total ratings: 371
Report this Post01-17-2015 09:04 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd never seen anything on them before. Would there be any specific advantage to using these calipers over others that could be had just as cheap, and are less complex?
Total ratings: 200
Report this Post01-17-2015 10:07 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is this for the front? It might be easier to just go with the Grand Am brake conversion...
TommyRocker
Report this Post01-17-2015 10:33 PM Click Here to See the Profile for TommyRockerSend a Private Message to TommyRockerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe the 240 uses a 5X108 pattern, so you'd have to drill something or change wheels or mod it somehow. I think 240 guys like to upgrade to later V70r Brembos because all that is required for THEM is a caliper adapter. Or something... I always laugh when the locost guys talk about using the Fiero bits because most Fiero guys looking for performance can't get away from them fast enough (though they'd obviously work better in a 1000 pound car).
cmechmann
Report this Post01-17-2015 11:33 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's not as much as what rotor is used as much as it is how the caliper is mounted right to the spindle. The trick is finding the right rotor and/or hub.
Here are 2 of the sites I looked at.
http://www.ozgemini.com/for...iewtopic.php?t=15659
http://www.scimitarweb.co.u...=4&t=10755&mobile=on
[This message has been edited by cmechmann (edited 01-17-2015).]
