  Cleaning Buffing/Polishing Pads
Cleaning Buffing/Polishing Pads by ILVMYGT
Started on: 01-16-2015 08:47 PM
Replies: 1 (144 views)
Last post by: 82-T/A [At Work] on 01-16-2015 10:17 PM
ILVMYGT
Report this Post01-16-2015 08:47 PM Click Here to See the Profile for ILVMYGTSend a Private Message to ILVMYGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the best way to clean wool and foam buffing pads. For the wool there is a "Spur tool" that will clean some of the compound out, but what can you use to deep clean the pads. Can you use something like Dawn or Simple Green to clean the pads or will that leave a residue. Is a special cleaning solution required? What are the recommendation?
Thanks
88 GT 5 Speed Black with gray interior
3800 SCII Swap.
Paint in Progress
IT RUNS!!
IT'S QUICK!!
"Real integrity is doing the right thing, knowing that nobody's going to know whether you did it or not."
Total ratings: 202
Report this Post01-16-2015 10:17 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
Pressure washer! Seriously, use a pressure washer to clean them, they'll be spotless.
