  starter shims
starter shims by petehiggins75
Started on: 01-16-2015 07:57 PM
Replies: 6 (661 views)
Last post by: theogre on 09-16-2020 11:12 PM
petehiggins75
Report this Post01-16-2015 07:57 PM Click Here to See the Profile for petehiggins75Click Here to visit petehiggins75's HomePageSend a Private Message to petehiggins75Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can anyone please tell me how many shims to use when i go to replace my starter.i have an86 duke.there appears to be none currently on the starter...thanks
Total ratings: 200
Report this Post01-16-2015 10:13 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
There's no set amount, it really depends on the proper clearance. When you replace your starter, you will definitely need one, just because rebuilt starters may be resurface. I would get to 1/16th" spacers, start with one, and if there's no grinding or anything and it's smooth, then you're good.
Report this Post01-16-2015 11:44 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Never trust old shim setup to work w/ another starter.
Many brands come w/ shims and correct gauge. Automatic trans is hard to use the gauge... You need to find wire same size and bend that to work.
See my Cave, Starter
petehiggins75
Report this Post01-17-2015 06:58 AM Click Here to See the Profile for petehiggins75Click Here to visit petehiggins75's HomePageSend a Private Message to petehiggins75Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you t-a and ogre
fierosound
Total ratings: 286
Report this Post09-16-2020 05:17 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've never figured out how anyone manages to check this in the car.
With transmission off on a cradle, sure it's easy to see starter/flywheel tooth engagement.
But with engine/transmission in the car, even with transmission splash shield off, I can't see shi... anything...
[This message has been edited by fierosound (edited 09-16-2020).]
Report this Post09-16-2020 08:14 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very true. That why we paint the starter gear with white water latex paint before installing the starter. After the paint dries you can tell if the gear meshes properly by looking at the way the paint rubs off when in contact with the flywheel/flexplate.
Report this Post09-16-2020 11:12 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
any starter may need shim(s) or not. And any replacement starter might need same or different then old unit.
Many starters you buy at stores have shims and gauge to install right. If not...
