  What is this stuff, and where do I get more?
What is this stuff, and where do I get more? by zzzhuh
Started on: 01-15-2015 07:20 PM
Replies: 6 (377 views)
Last post by: olejoedad on 01-17-2015 08:50 AM
zzzhuh
Report this Post01-15-2015 07:20 PM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today I got my GT tail lens from The Fiero Factory, along with an isolation relay. My other one seems to have more 'goop' inside of it.
Here is the new one, on the bottom ports it has a very small if any goop. Im assuming it helps with a connection and it looks like it could use some new stuff. Any idea what it is? Where I can buy some?
BTW, The Fiero Factory rocks, if you guys are looking for pieces and can't find them in the mall, definitely give em a call.
fieromatty
Report this Post01-15-2015 07:46 PM Click Here to See the Profile for fieromattySend a Private Message to fieromattyEdit/Delete MessageReply w/QuoteDirect Link to This Post
zzzhuh
Report this Post01-15-2015 07:58 PM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by fieromatty:
Its called Dielectric Grease
https://www.google.com/?gws...#q=dielectric+grease
You rock man! Thanks.
PaulJK
Total ratings: 237
Report this Post01-16-2015 05:56 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it was me, I'd just scoop it out of the old relay with a popsicle stick before i throw the old relay away.
[This message has been edited by PaulJK (edited 01-16-2015).]
zzzhuh
Report this Post01-16-2015 09:50 PM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took out all the old stuff and put brand new stuff in.
When your doing this:
Don't over do it, make sure it is at the bottom and spreads out evenly. Don't try to get too much on the prongs because it has a possibility on restricting the connection. Just my .2
Report this Post01-17-2015 12:30 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope. most Dielectric "Grease" are silicon oil based... Does work most times.
GM likely used "Bulb Grease" or something relative to that and you can get it under that name.
Bulb grease doesn't melt/run easily. Silicon grease will, faster when parts get hot.
Report this Post01-17-2015 08:50 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The pin/socket connection makes metal to metal contact, this is not an issue.
