  ZZP PLog question
ZZP PLog question by cam-a-lot
Started on: 01-12-2015 09:45 PM
Replies: 9 (680 views)
Last post by: mitchjl22 on 01-18-2015 03:47 AM
cam-a-lot
Total ratings: 97
Report this Post01-12-2015 09:45 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am collecting a few parts, as my engine/trans combo will be pulled this spring to get properly mounted. It is a good time to finally re-do my exhaust. I am planning to go back to stock manifolds and make a simple exhaust. I do see the big restriction on the 3800 rear manifold and looked into the ZZP PLog. I am wondering how many people on here have bought the new style that is currently for sale. Any cracking problems? Any dyno results to verify the claims of more HP? Any issues with fitting the stock heat shield or dip stick?
thanks
MstangsBware
Total ratings: 459
Report this Post01-13-2015 02:33 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks
I have used several of the SS version PLOG and have had no issues. Big improvement over the stock manifold.
cam-a-lot
Total ratings: 97
Report this Post01-13-2015 09:32 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good enough for me, given that you are one of the most experienced swap guys on the forum. I will order one
Any suggestions on what gasket to use? Is their crossover pipe of any value (I don't care about appearance as much- just want good flow and reliability)
MstangsBware
Total ratings: 459
Report this Post01-14-2015 08:17 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cross over I believe is just a coated stock pipe. If u have the extra change then doesn't hurt to help with the heat. Stock gaskets. Reuse the ones on ur swap unless they r messed up for some reason.
Steel
Report this Post01-16-2015 12:09 AM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
The SS plog's are better.. the regular steel logs rust bad at the welds quickly and blow out/crack there pretty easily.
sco77
Report this Post01-16-2015 05:53 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had a stainless zzp plog on my grand prix since around early 2009, you will have no issues at all with the stainless version... The newer style mild steel is probably better than the earlier ones but they have still been known to crack.
86 Fiero GT: 3800sc/Manual, Cam/Mods.
[This message has been edited by sco77 (edited 01-16-2015).]
mitchjl22
Report this Post01-17-2015 02:29 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
My plog won't fit with my A/C....
-Mitch
1fast2m4
Report this Post01-17-2015 04:25 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
what ac pump are you using? mine fit with no issues
1986 SE 3800SC/4t65eHD (12.871@104.96)
HX-40, FrozenBoost I/C, 80lb injectors & E85 Coming soon.....
1fast2m4
Report this Post01-17-2015 05:06 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
1fast2m4
Member since Feb 2013
I was hoping I had a pic of the P-log and the A/C pump but I don't I did mount the P-log Before I removed the A/C though.
Here I a Pic of my A/C pump installed.
And here is the P-Log installed
But I removed the A/C with the powerlog installed
mitchjl22
Report this Post01-18-2015 03:47 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well since you asked, both.
I started out with the one that came with my motor which is the smaller block mounted scroll type compressor, it fit snugly to say the least.
Then when I received my AC lines, they had the wrong fitting for the AC comp, so I went to the JY and got a series 2 pump with brackets.... that one actually hit the plog, so i googled it ant pappy had the same problem on his build so he "clearanced" the compressor to fit.
-Mitch
