  fiero gauge
fiero gauge by dthami22
Started on: 01-12-2015 08:02 PM
Replies: 3 (422 views)
Last post by: Spoon on 01-15-2015 10:11 PM
dthami22
Report this Post01-12-2015 08:02 PM Click Here to See the Profile for dthami22Send a Private Message to dthami22Edit/Delete MessageReply w/QuoteDirect Link to This Post
hello,
what is the thin plastic backing with all of the electronics on the behind the gauge cluster called? its what the harnesses plug into. mine is damaged and i need to replace this part. thanks!
Bloozberry
Total ratings: 311
Report this Post01-12-2015 08:11 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's a flexible printed circuit, though I've heard it called other things as well.
Shho13
Report this Post01-14-2015 02:19 AM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
It would probably be easier to just get a cluster from somewhere as opposed to replacing the flexible circuit board back there, that way it's just plug and play with no fooling around...
"Discord"
( ͡° ͜ʖ ͡°)
Spoon
Total ratings: 61
Report this Post01-15-2015 10:11 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Save yourself some money. Go to the bone yard and pull a cluster. Carefully remove the film circuit from behind the cluster. It's real easy and you wont have to buy a more than what you need,,,. a child could do it!
Now for the most important part. Put the cluster back just the way you found it and connect all the plugs. Don't leave any clues behind that it was ever removed and nobody will ever know. :
Spoon
[This message has been edited by Spoon (edited 01-15-2015).]
