| | | quote | Originally posted by racingfortheson:
Yes it is tan and purple but where does it pin into the computer? |
tan E15- purple F14 rear and purple B7- tan A7 front are the pins I think. double check
I suggest following only the pinouts for the computer you are using, be careful mickeys pinouts are for the early computer. you could confuse yourself easily, as they are similar.
If it was me (and I did have to make this decision once), Id wire it as mickeys and get an older number computer. Unless you need the 2 o2 sensors, or obd1.5 for some reason. but don't let me tell you what you should do
[This message has been edited by gen2muchwork (edited 01-13-2015).]
