  What is the difference between 1984 and 85-88 door skins.
What is the difference between 1984 and 85-88 door skins. by woodyhere
Started on: 01-09-2015 03:49 PM
Replies: 8 (619 views)
Last post by: woodyhere on 01-11-2015 08:50 PM
woodyhere
Report this Post01-09-2015 03:49 PM Click Here to See the Profile for woodyhereSend a Private Message to woodyhereEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm looking for a door skin for my 84 sport coup. Will a newer door skin fit with modifications?
Thanks
woodys 427
[This message has been edited by woodyhere (edited 01-09-2015).]
Report this Post01-09-2015 06:36 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe......Both doors are described in this 'HowTo'. 84 doors should be easy to find, though.
https://www.fiero.nl/forum/Forum9/HTML/000019.html
[This message has been edited by Gall757 (edited 01-09-2015).]
woodyhere
Report this Post01-09-2015 06:58 PM Click Here to See the Profile for woodyhereSend a Private Message to woodyhereEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess that couldn't be more clear. Thanks for the great link. I had my 87 apart to put in dew wipers but read the 84's are different. That clears it up!
woodys 427
David Hambleton
Report this Post01-09-2015 09:12 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry the pics aren't better.
The gap between the windows and the door skins on the '84s is about 1/8" bigger.
The '84s need wider dew wipes.
'84 doorskin to window gap:
'86 ('85 to '88):
woodyhere
Report this Post01-09-2015 10:42 PM Click Here to See the Profile for woodyhereSend a Private Message to woodyhereEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's interesting about the gaps. I was talking with one of the fellows that makes due wipers and he told me late 84's have the narrower gap. I measured my 87 and it's about 5/8th, my 84 measured the same! I guess I lucked out. Thanks for going to the trouble to measure and post pictures
woodys 427
David Hambleton
Report this Post01-09-2015 11:59 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero Store warns about the difference between '84s and the rest in their info about dew wipes. I got a set for my '86 and there would be an open gap if I used the same ones on my '84.
Seajai (Chris) makes dew wipes now too, but I'm not aware if he's done any for the '84s with a bigger gap.
woodyhere
Report this Post01-10-2015 12:54 AM Click Here to See the Profile for woodyhereSend a Private Message to woodyhereEdit/Delete MessageReply w/QuoteDirect Link to This Post
Chris emailed me the info on the early - late 84 width. I have to take off a skin anyway so it will be interesting if it has 3 push fasteners at the top or a hooked edge. Mine definitely measure 5/8 inch. It's possible my doors aren't 84's, just happen to be on an 84.
woodys 427
seajai
Total ratings: 51
Report this Post01-10-2015 11:56 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Early design door panels have a notch at the end wheres the late 84 to 88 do not. From what I can tell, 84's produced after April-May of 1984 have the 85-up outer skin.
Here is a pic of the 1st design door with my dew wipe installed, you can see the gap between the dew and the skin.
[This message has been edited by seajai (edited 01-10-2015).]
woodyhere
Report this Post01-11-2015 08:50 PM Click Here to See the Profile for woodyhereSend a Private Message to woodyhereEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the later design. I'll have to get a pair ordered from you Chris. Thanks for the pics!
woodys 427
