  2.8 Exhaust manifold glowing orange
2.8 Exhaust manifold glowing orange by Fier-oh41229
Started on: 12-26-2014 06:06 PM
Replies: 6 (383 views)
Last post by: bobace455 on 12-28-2014 02:48 PM
Fier-oh41229
Report this Post12-26-2014 06:06 PM Click Here to See the Profile for Fier-oh41229Send a Private Message to Fier-oh41229Edit/Delete MessageReply w/QuoteDirect Link to This Post
When i got the car (88 formula) the idle fluctuated quite a lot the egr needed replacing and the exhaust manifold would glow. I replaced the egr tube and valve replaced my ground wire (as well as added a second one) and now it idles fine but it still glows orange and i cant figure out why. My thought is its because a sensor is getting a wrong reading? Maybe because it went bad or a vacuum line has a leak and its causing it to run lean? Any ideas? Thanks - Dave
mcguiver3
Report this Post12-26-2014 08:44 PM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Definitely a lean condition.
Many causes, more than likely a major vacuum leak.
Or clogged injectors.
mcguiver3
Report this Post12-26-2014 08:46 PM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
mcguiver3
Member since Jan 2012
Try spraying some carb cleaner around and see if the idle picks up.
There is your leak.
88FieroGT TTops
Report this Post12-26-2014 09:40 PM Click Here to See the Profile for 88FieroGT TTopsSend a Private Message to 88FieroGT TTopsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had the same--O2 sensor.
Pat Jones
Fier-oh41229
Report this Post12-28-2014 11:18 AM Click Here to See the Profile for Fier-oh41229Send a Private Message to Fier-oh41229Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! It was the oxygen sensor. Exhaust looks normal. But now it has a high idle around 2k. Any ideas?
Fier-oh41229
Report this Post12-28-2014 11:51 AM Click Here to See the Profile for Fier-oh41229Send a Private Message to Fier-oh41229Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fier-oh41229
Member since Dec 2012
And now it won't start. ????
bobace455
Report this Post12-28-2014 02:48 PM Click Here to See the Profile for bobace455Send a Private Message to bobace455Edit/Delete MessageReply w/QuoteDirect Link to This Post
Burnt/leaking exhaust valve will cause red exhaust manifold. Try to pinpoint the cylinder that it glows red around and do a compression test - it should show up there.
