| | | quote | Originally posted by Jayfelt:
What dose removing the CSI benefit? |
Mainly just the elimination of a source of leaks. The metal line between the fuel rail and the injector is often brittle and can be damaged if you remove the fuel rail to change injectors. Some people have had issues sealing the metal line upon re-installing it to the fitting on the fuel rail. Or the injector itself could leak fuel and replacements are not available. Some people eliminate it just to reduce clutter.
Most people don't miss not having a cold start injector. Maybe a couple more seconds of cranking when the car is cold. By design, the injector only sprays when the starter is engaged so it normally sees very little use.
