  How to dissasemble an F23
How to dissasemble an F23 by mcguiver3
Started on: 12-15-2014 07:31 AM
Replies: 5 (196 views)
Last post by: mcguiver3 on 12-16-2014 07:29 PM
mcguiver3
Report this Post12-15-2014 07:31 AM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
I tried to search this out and found nothing.
Is there a thread on this?
I saw a video a while back but it was in German and totally useless.
Any help?
FIEROFLYER
Total ratings: 180
Report this Post12-15-2014 07:53 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
There was a sheet floating around showing step by step instructions will see if i can find a copy for you.
DARN Cars now open with
FIEROFLYER
Total ratings: 180
Report this Post12-15-2014 07:54 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
FIEROFLYER
Member since Oct 2002
There was a sheet floating around showing step by step instructions will see if I can find a copy for you.
mcguiver3
Report this Post12-16-2014 03:22 PM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Found some info on splitting the case but the bolt/cap on the bearing under the black seal is not coming loose.
Any thoughts?
is it a right or left hand thread?
Torque?
Holding the input shaft during the job?
Justinbart
Total ratings: 119
Report this Post12-16-2014 06:37 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any thoughts?
Torque?
It's the normal thread, Left to loosen. You need put the trans in gear and lock down the input shaft with a tool. Then you will need a 3 foot breaker bar and a lot of muscle. Its a ***** .
Turbo 3800 E85 F23 5spd spec5
10.91@133.1
mcguiver3
Report this Post12-16-2014 07:29 PM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any suggestions on holding the input shaft?
Don't want to bugger up the splines.
