  clutch problem
clutch problem by Erickson307
Started on: 12-08-2014 10:31 AM
Replies: 3 (94 views)
Last post by: Erickson307 on 12-08-2014 12:55 PM
Erickson307
Report this Post12-08-2014 10:31 AM Click Here to See the Profile for Erickson307Send a Private Message to Erickson307Edit/Delete MessageReply w/QuoteDirect Link to This Post
new pressure plate and clutch disc for 2.8 v6 with 5 speed has new 4 cyl throw out bearing because its the Isuzu 5 speed new slave cylinder about 6 months ago put new clutch components in last week and have had no clutch sense i push the pedal and nothing happens i know its engaged because it turns the wheels when running in gear but cant get it to disengage and pedal has no Resistance to it its been bled more than a few times and still nothing any ideas on what this could be?
Csjag
Report this Post12-08-2014 10:56 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the slave cylinder moving an inch or so when the clutch pedal is depressed?
Csjag
Report this Post12-08-2014 11:00 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Csjag
Member since Dec 2013
The seal in your master cylinder could also be blown so that when its put under pressure it fails to hold the pressure. Are you able to disengage the clutch at the transmission by moving the lever by hand?
Erickson307
Report this Post12-08-2014 12:55 PM Click Here to See the Profile for Erickson307Send a Private Message to Erickson307Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have not measured but from what I can tell it looks to be about an inch of travel I have not tried to move it yet by hand
