  clitch master cylinder
clitch master cylinder by mikej6
Started on: 12-06-2014 11:53 AM
Replies: 3 (89 views)
Last post by: Csjag on 12-07-2014 04:43 PM
mikej6
Report this Post12-06-2014 11:53 AM Click Here to See the Profile for mikej6Send a Private Message to mikej6Edit/Delete MessageReply w/QuoteDirect Link to This Post
has any one ever tryed a larger clutch mastercylinder
and what would fit
I changed new master cylinder and slave and bleed
still have to push clutch to almost to floor to shift
Report this Post12-06-2014 12:18 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
That means there is still air in the system...a larger master cylinder won't help that problem.
If you pump the clutch pedal rapidly, does the dis-engagement position change?
[This message has been edited by Gall757 (edited 12-06-2014).]
tebailey
Report this Post12-06-2014 12:27 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine did the same thing until I replaced the pedal. It didn't look bent, but it was. Replace your clutch pedal with a new steel one.
Csjag
Report this Post12-07-2014 04:43 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also could install Rodney Dickman's dual seal slave cylinder and use his bleeder screw with the one way valve
