I have replaced a bad rod bearing before but not on a Fiero. If the business end of the rod is egg-shaped from knocking, all bets are off, "Sort-of".
You may want to check for journal scoring. If scored all bets are off again, "Sort-of".
I once found myself in a pinch such as yours and an old -schooler told me about a trick fix. Find a worn out leather belt and soak it in some oil. Cut a length of belt equal to the circumference of a rod bearing. Poke oiler holes in the appropriate places and put the leather bearing in place.
When you fire it up the expression on your face will be priceless!
No,,,,,,,,,,,, I wouldn't advise replacing the remaining 5.
Spoon
