  trying to remove my shift knob!!!! ugh
trying to remove my shift knob!!!! ugh by busa_powered
Started on: 12-03-2014 02:15 AM
Replies: 5 (426 views)
Last post by: 84fiero123 on 12-04-2014 07:44 PM
busa_powered
Report this Post12-03-2014 02:15 AM Click Here to See the Profile for busa_poweredSend a Private Message to busa_poweredEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am trying to remove my auto shifter knob on my 87 gt.
I read the post on here about removing the horse staple on the back of the shifter.
I have done that and am trying to pull it off
There seems to be sort of the same type of thing under the black button, there is a smaller staple. I pull on the staple but it wont come out like the first one did. It seems to control the button when you press it in.
IS this what I am suppose to be doing?
Am I doing something wrong?
RTingey
Report this Post12-03-2014 04:55 AM Click Here to See the Profile for RTingeySend a Private Message to RTingeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
All I did when I removed my shifter knob was the large pin. Mine just needed a little convincing (a swift smack up on both sides) I would not remove the smaller pin unless you plan on reupholstering the knob because that staple is clamped on the other side. I hope this helps.
seajai
Total ratings: 51
Report this Post12-03-2014 06:38 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Once you remove clip #10 the knob should come off. You may need to give it a whack to jar it loose.
jaskispyder
Total ratings: 205
Report this Post12-03-2014 08:00 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup, it pulls right up, once the clip in front is removed. Get something to tap on it from the underside.
busa_powered
Report this Post12-03-2014 10:05 AM Click Here to See the Profile for busa_poweredSend a Private Message to busa_poweredEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks guys, I will try this again!
84fiero123
Total ratings: 325
Report this Post12-04-2014 07:44 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I used a round handled ratchets handle and tapped it a few times under opposite sides alternately and it popped right up.
Steve
