  Automatic trans removal
Automatic trans removal by Fierotregg
Started on: 12-01-2014 12:49 PM
Replies: 2 (330 views)
Last post by: olejoedad on 12-02-2014 11:10 PM
Fierotregg
Report this Post12-01-2014 12:49 PM Click Here to See the Profile for FierotreggSend a Private Message to FierotreggEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the best and/or easiest way to remove an automatic trans from my Fiero? Dropping the entire cradle? Tilting it down? Thanks in advance.
weloveour86se
Total ratings: 75
Report this Post12-01-2014 08:11 PM Click Here to See the Profile for weloveour86seSend a Private Message to weloveour86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dropping entire cradle. The tranny bell housing won't fit around the torque converter pretty much any other way. You are going to need to slide that tranny out about 5-6 inches at least and there is nowhere near enough space in the engine bay.
But this way you can take care of all the other stuff and really get to know your engine!
GL!
Report this Post12-02-2014 11:10 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Suspend drivetrain with bridge device. Unbolt drivetrain mounts from cradle. Disconnect exhaust downpipe from crossover. Unbolt calipers from caliper mounts and hang. Remove axle nut. Remove strut/knuckle by removing top three nuts and disconnecting ball joint from a-arm (88 is different) and pulling off of axle. Remove axles. Disconnect and loop trans cooling hoses. Remove cradle, leaving drivetrain suspended. Remove bell housing bolts and dust shield. Disconnect shift cable and TCC plug. Remove engine to trans brace. Remove torque converter to flexplate bolts. Lower transmission with cherry picker.
