  SCCA ITA Brake prep question
SCCA ITA Brake prep question by 1fast2m4
Started on: 11-30-2014 07:01 PM
Replies: 5 (222 views)
Last post by: 1fast2m4 on 12-03-2014 05:25 PM
1fast2m4
Report this Post11-30-2014 07:01 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm thinking about setting up my Parts car (85 GT) for the SCCA ITA class
In the rule book they specify that SOCK / OEM Brake rotors & calipers MUST be used or equivalent replacement parts
also the SCCA specifically requires that a Fiero in the ITA class must run ((Front) 260mm or 247mm Disc & (Rear) 260mm or 247mm Disk
247mm = 9.7"
260mm = 10.2"
So my question in what "Stock/OEM" brakes are 10.2"?
1986 SE 3800SC/4t65eHD (12.871@104.96)
HX-40, FrozenBoost I/C, 80lb injectors & E85 Coming soon.....
Report this Post11-30-2014 07:19 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The stock 88 brake rotors are 265mm in diameter.
1fast2m4
Report this Post11-30-2014 07:27 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thats what I was afraid of, in a very direct but round about way they are saying you can run '88 brakes on a 84-88 Fiero and Vice-Versa
To road race with '88 brake parts would be cost prohibitive, think 84-87 OEM brakes are up to the task ?
Phil
Total ratings: 154
Report this Post11-30-2014 08:40 PM Click Here to See the Profile for PhilSend a Private Message to PhilEdit/Delete MessageReply w/QuoteDirect Link to This Post
The rules don't say anything about the booster though.
1fast2m4
Report this Post11-30-2014 09:16 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
The rules do however say if it's not in the rules than it needs to be Stock/ OEM
I was hoping the grand am brake upgrade might be legal. (it should be..... Stock appearing single piston caliper & stock diameter 9.7" rotors)
I Gaurentee I would never be busted on if I ran GranAm brakes, but I don't want to be a "Cheater" I just want my Comp license and have some fun.
[This message has been edited by 1fast2m4 (edited 11-30-2014).]
1fast2m4
Report this Post12-03-2014 05:25 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
It seems like NASA PT and SCCA IT are just about the same thing, and it seems like if your legal in NASA PT they let you run in SCCA IT and vice versa other than that we can go full chassis car and run in GT1 or GT2 but that's a bit much, since me and a few friends just want our comp license.
I'll just put the highest quality pads and rotors on her and see how it does. I'm not worried about the performance of the stock brakes, I was just concerned about warping, rotors rarely warp while driving.... as long as I take care of them a cool them down before parking I'm sure they will do alright. After all other cars in the same class have to run 7" rotors in the front and drum brakes in the rear
