  radio amp
radio amp by larry mimbs
Started on: 11-25-2014 05:43 PM
Replies: 1 (135 views)
Last post by: donuteater306 on 11-25-2014 11:28 PM
larry mimbs
Report this Post11-25-2014 05:43 PM Click Here to See the Profile for larry mimbsSend a Private Message to larry mimbsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is there a simple way to tell if an 88 model radio has a remote amp?
donuteater306
Report this Post11-25-2014 11:28 PM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well, luckily with a Fiero being the size of a Fiero. Not too many places to hide an aftermarket amp. Look behind and under the seats.
Factory DelcoGM radios in a Fiero only came with an internal amp. Unless it has the factory Performance Sound. If you have it, there will be slider switch on the overhead console that says "performance sound." The amp for it is behind the carpet on the right side of the center console. Pull the carpet back and it wil be screwed to the plastic panel that's between the carpet and console. It's a small box that's approx. 5"x5"x2" Hope this helps.
