  What is this vacuum tube supposed to connect to?
What is this vacuum tube supposed to connect to? by nickwstp
Started on: 11-25-2014 02:07 PM
Replies: 5 (288 views)
Last post by: MarkS on 11-28-2014 10:37 AM
nickwstp
Report this Post11-25-2014 02:07 PM Click Here to See the Profile for nickwstpSend a Private Message to nickwstpEdit/Delete MessageReply w/QuoteDirect Link to This Post
The car doesn't run terribly bad without it connected but I'd like to know, Thanks!
Report this Post11-25-2014 03:58 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
There is a long story about that tube that involves a recall from General Motors. You can learn much more from the Archives...but here is a thread to get you started.
https://www.fiero.nl/forum/A...130314-2-115910.html
[This message has been edited by Gall757 (edited 11-25-2014).]
Fiero84Freak
Report this Post11-25-2014 04:13 PM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
^^^ The only thing you have to worry about is the smaller tube below it that is attached to it. That smaller tube feeds into the EGR solenoid (it goes to the round part of the solenoid on the right side of the tube and IIRC the Evap canister on the left side of the tube). Otherwise GM just left the tube there as part of the PCV & intake recalls for the V6 cars early on and capped one end off, as it would have required them to modify the part to separate the EGR tube or make an entirely new part (which they already had to do to address the PCV issues).
There is also a rubber tube that would have feed into the intake canister. This wasn't changed out, as capping the end of the main tube resolved any problems. You can simply cap off the portion of the air canister the tube went to and it'll be ok.
nickwstp
Report this Post11-28-2014 04:27 AM Click Here to See the Profile for nickwstpSend a Private Message to nickwstpEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks a ton for the info! Glad that one of the many previous owners took care of some of the recall stuff. Sure does seem like there would be a vacuum leak there, though I can't feel anything when I put my finger on it while the car is running. Thanks again!
Report this Post11-28-2014 09:58 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Neither of those tubes are connected to the Evap Canister. The small tube still connects to the underside of the air filter canister and the passenger end connects to the end of the EGR solenoid. You won't feel any vacuum there unless you ride in the engine bay while the car is traveling down the highway. The EGR solenoid isn't in operation except in certain conditions while driving at highway speeds, generally at times of deceleration.
MarkS
Report this Post11-28-2014 10:37 AM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
I removed the whole assembly from the firewall and used a separate filter for the EGR solenoid. Plugged the open ports on the air cleaner canister. I found this worthwhile as it gives more room back there when changing plugs, replacing the exhaust manifold etc.
BR's,
Mark
86 SE V6 4 speed
86 SE V6 Auto
2008 G6 GT "Street" Coupe
2005 Buick 3.6 Rendezvous
2001 Olds Silhouette (AKA The Band Van)
