  4.9 Auto Shifter Adapter Info needed
4.9 Auto Shifter Adapter Info needed by jokerb90
Started on: 11-15-2014 04:42 PM
Replies: 3 (336 views)
Last post by: phonedawgz on 11-16-2014 08:15 AM
jokerb90
Report this Post11-15-2014 04:42 PM Click Here to See the Profile for jokerb90Send a Private Message to jokerb90Edit/Delete MessageReply w/QuoteDirect Link to This Post
Second 4.9, first auto
Have 4.9 in car, realized shift cable is not just plug and play.....d'oh
Tried search, maybe using the wrong terms.
Need a how to using the caddy bracket, as the stock one is gone.
Please assist, pictures are awesome,
[This message has been edited by jokerb90 (edited 11-15-2014).]
Report this Post11-15-2014 10:43 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
To use the 4T60e trans, the shift lever needs to be shortened, installed in reverse, and a shift cable bracket made from parts of the 4T60e and TH125 transmissions. Basically its the 4T60e bracket bottom (that's bolts on) with the Fiero cable holder portion welded on to it. I am away from home now but if no one responds with the info I can post it on Monday.
[This message has been edited by Dennis LaGrua (edited 11-16-2014).]
jokerb90
Report this Post11-16-2014 06:08 AM Click Here to See the Profile for jokerb90Send a Private Message to jokerb90Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dennis, makes good sense, and I can visualize how it would work. Thanks.
Will source a bracket (headed to PFF mall) and write up a how to when done.
Thanks again, Mike
[This message has been edited by jokerb90 (edited 11-16-2014).]
Total ratings: 290
Report this Post11-16-2014 08:15 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
4.0 came with the 4t60e
