  Third brake light template thing
Third brake light template thing by busa_powered
Started on: 11-14-2014 02:28 AM
Replies: 3 (219 views)
Last post by: Fiero84Freak on 11-15-2014 05:44 PM
busa_powered
Report this Post11-14-2014 02:28 AM Click Here to See the Profile for busa_poweredSend a Private Message to busa_poweredEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the Fiero GT template that attaches to the third brake light inside the car.
I tried to remove it and it feels like its stuck on there pretty good.
How does it attach when you apply them, glue, tape, or does it just sit over the light?
Mine is on there pretty good and I would like to have it gone.
Thanks!
Report this Post11-14-2014 11:46 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think you have to take the housing apart.
Report this Post11-14-2014 01:19 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
That, some-one glued it, or lens/rubber is melted to the cutout.
889 bulb does generate heat...
Fiero84Freak
Report this Post11-15-2014 05:44 PM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm guessing you got the one from the Fiero Store. I had the same "Fiero GT" insert on my car bombed black.
You just remove the housing and the gasket and slip the piece into where the gasket is. As TheOrge has pointed out, a common problem with the third brake light housing is heat really does a number on the components in there; to the point that there have been instances of melted housings (a similar issue exists with fastback GT taillights where "PONTIAC" lights up).
You don't have to secure it by any means. When you reassemble the third brake light housing with the insert inside the gasket, it sandwiches and stays in place.
EDIT: Sorry I see you're asking about how to remove it. Yeah everything I mentioned above should be par, but if you remove the housing shroud and gasket the insert should fall or come out.
[This message has been edited by Fiero84Freak (edited 11-15-2014).]
