| quote | Originally posted by perceptionist: How does this occur? Isn't the heater hose just outside the heater core the highest point in a sealed system? |
No. Fiero Tstat cap is highest point but doesn't matter to heater, or even Tstat housing or engine...
Tstat close then WP will try to force
all coolant flow to heater.
The
amount of flow will forces most/all air out of heater loop. (compare to river rapids) Any trapped air left over will move over time.
Even Tstat housing and engine will purge some air to radiator because of coolant flow. (Coolant level too low will stop that.)
Radiator have enough tubes to slow down coolant flow (like fat wide river) and let air to stagnant and stay there.
The Radiator cap will purge that air thru overflow tank when system get hot.
Note: Heater core looks like but not same thing are radiator.
Core flow... inlet pipe thru bottom/top half of core to other tank then return to top/bottom then return to engine.
Many times people saying to burp the system because often many have air leaks when engine cools down or did not fill system right. (Jack the car etc to burp the system then have big system problem or have no clue.)
A fact many don't get...
Cooling coolant generates vacuum. What we often call radiator cap check valve is really a vacuum valve, there to suck coolant/air in a control manner. (Air if tube/cap leaks or is old car w/o overflow tank. Venting or Non-Vent caps does same job.)
Iffy cap(s), loose hose clamps, or WP seal can leak air in when engine cools.
