  Guess my Fiero doesnt like me
Guess my Fiero doesnt like me by busa_powered
Started on: 11-11-2014 02:58 AM
Replies: 3 (212 views)
Last post by: busa_powered on 11-12-2014 01:25 PM
busa_powered
Report this Post11-11-2014 02:58 AM Click Here to See the Profile for busa_poweredSend a Private Message to busa_poweredEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not a week after I bought my GT, the radiator felt it was time to blow its top.
Judging by the contents pouring out onto the pavement, the previous owner did not maintain the cooling system.
Radiator and thermostat were replaced.
I installed a new coolant tank, the previous one was broken on both tabs and held up with washers. Guess I missed that when I was looking under the hood during my prepurchase inspection
So my question is at what temperature does the radiator fan kick on?
I did look before asking this question and all the ones I found were in regard to with the AC on.
Thanks!
Report this Post11-11-2014 03:46 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The OEM switch will turn the fan on at 235°F. With a properly functioning cooling system, you may find that the rad fan almost never comes on (depending on where you live and the ambient temperature).
I've bought the fan switch from Rodney that turns the fan on at 210° instead of 235°. Works great with the recommended 195° thermostat.
[This message has been edited by Patrick (edited 11-11-2014).]
nickwstp
Report this Post11-11-2014 10:07 AM Click Here to See the Profile for nickwstpSend a Private Message to nickwstpEdit/Delete MessageReply w/QuoteDirect Link to This Post
Least you caught it quickly, My coolant tank fell off its tabs on the highway and the tank got cut up by the radiator fan causing a fatal overheat for the engine on my second drive of owning the car!
busa_powered
Report this Post11-12-2014 01:25 PM Click Here to See the Profile for busa_poweredSend a Private Message to busa_poweredEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks I ordered the fan switch!
