  Rim question
Rim question by newfiejeff
Started on: 11-10-2014 10:24 AM
Replies: 4 (162 views)
Last post by: 85 SE VIN 9 on 11-10-2014 04:28 PM
newfiejeff
Report this Post11-10-2014 10:24 AM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
1986 2M4
Hi, I have a question about rims and I probably should know the answer.
Is this the type of rim that came on the Fiero's back in 1986?
https://www.nlclassifieds.c...undland-NLCId1616408
jaskispyder
Total ratings: 205
Report this Post11-10-2014 11:06 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
They will fit - if they are from a sunbird - (have to watch the rear as the weights may hit the strut), but they are not exactly Fiero rims. The fiero rims look the same, but have a slight offset so as there is a 3/4"(?) step in from the bead part of the rim. This pushed the tires out a little. The sunbird rims are pretty much flush from the bead, across to the center.
http://tinyurl.com/pgzax5g
[This message has been edited by jaskispyder (edited 11-10-2014).]
newfiejeff
Report this Post11-10-2014 11:19 AM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Didn't realize that you could still buy them new.
jaskispyder
Total ratings: 205
Report this Post11-10-2014 11:34 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
They are most likey refurbished rims... I don't think you can get "new".
I have refinished 14" and 15" rims and have had first hand experience with sunbird rims as I didn't install them on my Fiero, but a friend did. And as I said, the inside weights hit a part of the strut.
More refinished/used rims: http://www.wheelcollision.com/po4.htm
(or look on ebay)
85 SE VIN 9
Report this Post11-10-2014 04:28 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
