  Kevlar clutch
Kevlar clutch by Fieroto300zx
Started on: 11-08-2014 10:28 PM
Replies: 3 (123 views)
Last post by: Joseph Upson on 11-09-2014 12:54 PM
Fieroto300zx
Report this Post11-08-2014 10:28 PM Click Here to See the Profile for Fieroto300zxSend a Private Message to Fieroto300zxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the Kevlar clutch worth putting in a 3.4 fiero and what makes it so much better than a heavy duty clutch ?
Joseph Upson
Total ratings: 88
Report this Post11-09-2014 11:07 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
It has a long service life and good grip from what I was told by a clutch builder. Use a sprung hub or it may scrub on engagement.
Report this Post11-09-2014 11:24 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
It is usually used for racing applications, and not recommended for street use. Most kevlar clutches have a heavy pedal, and will wear out your left leg in stop-and-go traffic, plus a lot of chatter.
[This message has been edited by Gall757 (edited 11-09-2014).]
Joseph Upson
Total ratings: 88
Report this Post11-09-2014 12:54 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been running one for 3 yrs, the chatter in my case has more to do with a nearly solid hub which is why I suggested a fully sprung hub to allow a little more engagement time to prevent it as I can engage the clutch without the noise but using a little more effort. Pedal hardness is determined by the pressure plate so if the stock plate is used it will not change.
[This message has been edited by Joseph Upson (edited 11-09-2014).]
