  TCI Rattler Torsional Vibration Absorber
TCI Rattler Torsional Vibration Absorber by mckaymotoworks
Started on: 11-08-2014 09:45 PM
Replies: 5 (241 views)
Last post by: theogre on 12-07-2014 12:01 AM
mckaymotoworks
Report this Post11-08-2014 09:45 PM Click Here to See the Profile for mckaymotoworksClick Here to visit mckaymotoworks's HomePageSend a Private Message to mckaymotoworksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any one have experience with this or more snake oil?
Rattler
Looks promising though pricey.
Ang84Indy
Report this Post11-09-2014 12:11 AM Click Here to See the Profile for Ang84IndySend a Private Message to Ang84IndyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't have any experience with them, but I have wanted to try one for quite some time. Seems like it would work very well.
mckaymotoworks
Report this Post11-09-2014 12:28 AM Click Here to See the Profile for mckaymotoworksClick Here to visit mckaymotoworks's HomePageSend a Private Message to mckaymotoworksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Made in my home state of Mississippi. I'll give this guys a call Monday, see what all the hoopla is about.
Report this Post11-09-2014 09:53 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of several designs of aftermarket harmonic balancers.
Does any work better than OE? Maybe. Likely for racing build engines.
see also www.fiero.nl/forum/Forum2/HTML/133877.html
likely made for v6 too.
warning that made for X engine might not be exact replacement for OE stock...
if the "flange" area where pulley are mounted move in/out, even a tiny bit, then you must re-align the pulley(s) or you will have belt problems.
mckaymotoworks
Report this Post12-06-2014 11:56 AM Click Here to See the Profile for mckaymotoworksClick Here to visit mckaymotoworks's HomePageSend a Private Message to mckaymotoworksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Having never seen an actual 88' crank, and asking a fellow member about their own 88' crank upgrade on a built 2.5, does the 88' crank essentially have this built in by cast for the DSI?
Or am I not understanding what was said? I apologize for the ignorance, still learning here and taking my time to pick components that will work together.
Ogre, edfiero also brought that up, I called the company, they said it should work. Luckily Summit has a good return policy, and their info does not specify which of the 2.5 engines.
So I may have to try it to find out, I will double check their return policy before ordering if this turns out to be the case.
Report this Post12-07-2014 12:01 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
87+ duke? won't work. Balancer IS the pulley.
Look up at rockauto etc for DORMAN Part # 594027 and others.
older duke... unless is small enough to fit inside pulley, won't work.
pictures here www.fiero.nl/forum/Forum1/HTML/086830.html#p13
Crank uses simple hub to mount the pulley. example ATP Part # 102193
[This message has been edited by theogre (edited 12-07-2014).]
