  Fiero front coil springs
Fiero front coil springs by Wittendorf1986
Started on: 11-08-2014 06:52 PM
Replies: 5 (457 views)
Last post by: theogre on 11-09-2014 11:31 AM
Wittendorf1986
Report this Post11-08-2014 06:52 PM Click Here to See the Profile for Wittendorf1986Send a Private Message to Wittendorf1986Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 85 se been working on and front coil springs are missing, I havent seen if brackets are gone or not but fiero store only has complete sets of front and rears,my rears are good. What can I do and where can I just get the fronts alone? I don't want to lower, I just want to keep stock. I have searched ebay and Craigslist no luck anyone have any ideas?
johnt671
Report this Post11-08-2014 07:58 PM Click Here to See the Profile for johnt671Send a Private Message to johnt671Edit/Delete MessageReply w/QuoteDirect Link to This Post
Post a want to buy in the mall section. People are always parting cars out.
Report this Post11-08-2014 08:47 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
See my Cave, RPO List
Page shows factory spring codes.
Make sure have same springs codes for front or rear. Mismatch springs on an axle can cause problems. Similar to flat tire etc.
Wittendorf1986
Report this Post11-08-2014 09:45 PM Click Here to See the Profile for Wittendorf1986Send a Private Message to Wittendorf1986Edit/Delete MessageReply w/QuoteDirect Link to This Post
Where can I find the codes front springs previous for some reason removed springs where are the codes on the rears
Lou6t4gto
Report this Post11-08-2014 11:36 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm sure someone here has a set they removed. use the want ads in the Mall.
Report this Post11-09-2014 11:31 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Read RPO label next to brake MC.
You don't need to match RPO label.
You do need to make sure front springs match each other. Example both are HZ.
You don't want 1 HZ and other HW. This can cause same problem as 1 tire w/ low air.
You can still find springs w/ own label from factory but many have fallen off.
