  3.4L Question
3.4L Question by zzzhuh
Started on: 11-07-2014 10:22 PM
Replies: 3 (124 views)
Last post by: NW-Fiero on 11-07-2014 11:45 PM
zzzhuh
Report this Post11-07-2014 10:22 PM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
With my engine swap being just around the corner, I want to find a nice set up for the 3.4PR engine. Assuming my exhaust has a leak, will these two products from TFS fit the 3.4 directly? Here are the links to the two products:
http://www.fierostore.com/P...px?s=54406&d=389&p=1
http://www.fierostore.com/P...px?s=95727&d=389&p=1 (if you bought these, how are they?)
Every fiero has a story, It's our job to keep that story alive.
NW-Fiero
Report this Post11-07-2014 11:13 PM Click Here to See the Profile for NW-FieroSend a Private Message to NW-FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Assuming you are doing a 2.8l to 3.4l swap, 93-95 Camaro/Firebird Block The heads are the same as the 2.8 heads . Exhaust will bolt right up.
zzzhuh
Report this Post11-07-2014 11:18 PM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome! Thanks for your input, yes I meant the 3.4PR engine.
Any idea if this will give me a few extra ponies?
NW-Fiero
Report this Post11-07-2014 11:45 PM Click Here to See the Profile for NW-FieroSend a Private Message to NW-FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
since the factory pipes were poorly assembled and are said to give an additional 10-15hp when ported. The new pipes should give you that with no problem. I would consider porting the y pipe to ensure a clear unobstructed flow.
