  clutch problem
clutch problem by Erickson307
Started on: 11-07-2014 10:08 AM
Replies: 1 (83 views)
Last post by: Gall757 on 11-07-2014 10:30 AM
Erickson307
Report this Post11-07-2014 10:08 AM Click Here to See the Profile for Erickson307Send a Private Message to Erickson307Edit/Delete MessageReply w/QuoteDirect Link to This Post
my clutch started slipping relly bad so i bleed it and it stopped for a couple days and than started doing it again i pulled the trans last night and removed the clutch and the disc still has fiber left on it its a little dis colered but the center looks purple from heat and the pressure plate is discolored and same with flywheel from heat my question is why is it slipping if the disc still has fiber on it and should i just replace it seance i have it this far apart?
Report this Post11-07-2014 10:30 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Look for wet surfaces, or any oil leaking from the main seal on the drive shaft. It does not take much.
