  Clutch Problem?
Clutch Problem? by Klondike
Started on: 11-06-2014 11:42 PM
Replies: 5 (133 views)
Last post by: Gall757 on 11-07-2014 10:33 AM
Klondike
Report this Post11-06-2014 11:42 PM Click Here to See the Profile for KlondikeSend a Private Message to KlondikeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an '88 GT with a V6 and 5-Spd Tranny.... Recently, I noticed some "feedback" through the clutch pedal when I depress it to shift gears (feels like a high frequency vibration), but the clutch does not "slip"... And, when shifting the gears, it seems to shift properly (no grinding, no difficulty shifting, no "strange" noises, etc.)... Any ideas about what is causing the "feedback" through the clutch pedal would be appreciated. Thanks!!
Report this Post11-07-2014 01:29 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 5-spd Getrags are known for a problem with the input shaft sleeve (or whatever it's called) breaking. Someone else with more info on this will chip in I'm sure.
This might be what you're feeling.
Kevin87FieroGT
Report this Post11-07-2014 10:12 AM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
May also be a bad throwout bearing.
Erickson307
Report this Post11-07-2014 10:14 AM Click Here to See the Profile for Erickson307Send a Private Message to Erickson307Edit/Delete MessageReply w/QuoteDirect Link to This Post
okay i also forgot to mention thats its a 5 speed isuzu
mcguiver3
Report this Post11-07-2014 10:25 AM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
A 5 spd Izusu in an 88 V6?
I thought they were all Getrage 282's
Interesting?
Report this Post11-07-2014 10:33 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
We've got a problem here with 2 threads with the same title.....Erickson belongs on the other thread.
