  need help! after starting engine idles rough, surges then dies
need help! after starting engine idles rough, surges then dies by James Lloyd
Started on: 11-06-2014 05:52 PM
Replies: 4 (396 views)
Last post by: imabaddude on 11-06-2014 06:32 PM
James Lloyd
Report this Post11-06-2014 05:52 PM Click Here to See the Profile for James LloydSend a Private Message to James LloydEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 86 GT that I have recently replaced the clutch on. I did this by removing the engine/cradle assembly. When I put everything back together, the engine stopped working. Before the clutch replacement the engine ran just fine. Now that it's all back together, the engine idles a little rough, then accelerates on its own,then dies. Any help would be wonderful as I am new to the Fiero world.
Report this Post11-06-2014 05:57 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the Forum!
Fieros are programmed to do this to new owners...sort of an initiation.........
imabaddude
Report this Post11-06-2014 06:18 PM Click Here to See the Profile for imabaddudeSend a Private Message to imabaddudeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any engine codes? Maybe you snapped a vacuum line.
James Lloyd
Report this Post11-06-2014 06:20 PM Click Here to See the Profile for James LloydSend a Private Message to James LloydEdit/Delete MessageReply w/QuoteDirect Link to This Post
While the engine is running the check engine light doesn't come on. Other than that , I'm not sure.
imabaddude
Report this Post11-06-2014 06:32 PM Click Here to See the Profile for imabaddudeSend a Private Message to imabaddudeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Use the ALDL to see if any are stored in the ECM. I had a similar issue and one of the vacuum lines broke where it ran underneath the upper intake, so I missed it on my first inspection of them.
