  How to split an F23
How to split an F23 by mcguiver3
Started on: 11-05-2014 07:20 AM
Replies: 9 (241 views)
Last post by: Grind on 11-06-2014 09:06 AM
mcguiver3
Report this Post11-05-2014 07:20 AM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Searched the forum and didn't find anything.
Is there a source to get the info?
I am planning to get the Quaife LSD and would try this install.
I've done a 282 before, is this similar?
Special tools required?
Or is it something better left to a tranny shop?
Does any one have a source for a used diff? The $1,200 is a bit stiff on the budget.
fierosound
Total ratings: 286
Report this Post11-05-2014 08:24 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you need a used stock diff and you are considering the LSD because you can't find one?
You can get another transmission for $500
Calgary time/temp
mcguiver3
Report this Post11-05-2014 11:29 AM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looking for a used Quaife LSD for the F23.
Although a new one would be a great Christmas present from my wife.
Grind
Report this Post11-05-2014 02:09 PM Click Here to See the Profile for GrindSend a Private Message to GrindEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just split an F23, last weekend. You need to put it in gear and stop the input shaft from turning, and remove this screw/bolt/retainer, that's under a rubber/metal cover, seen above right from input shaft. (Cover had been removed, in this picture.)
After that, it's a lot of screws to remove, then gently separate the case halves.
mcguiver3
Report this Post11-05-2014 03:35 PM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Once apart can the differential be removed or are there more steps to be able to it?
What is the preload on the differential? .004? I think that was what the 282 was.
Grind
Report this Post11-06-2014 12:57 AM Click Here to See the Profile for GrindSend a Private Message to GrindEdit/Delete MessageReply w/QuoteDirect Link to This Post
Once apart, the diff can be taken right out. No magic necessary. I do not know the preload.
Grind
Report this Post11-06-2014 01:26 AM Click Here to See the Profile for GrindSend a Private Message to GrindEdit/Delete MessageReply w/QuoteDirect Link to This Post
Grind
Member since Oct 2014
Also, I've heard of OBX differentials, a budget knock-off of the Quaife. They're abouta third the price.
mcguiver3
Report this Post11-06-2014 07:35 AM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
I did some research a while back on the OBX unit and it did not fair well.
The quality of the unit appears to be much lower than the Quaife.
If it is that simple to split the case I will give it a try but do need to know the pre-load on the bearings.
Anyone??????
Looks like I will be $1200 lighter in a few months.
Grind
Report this Post11-06-2014 07:57 AM Click Here to See the Profile for GrindSend a Private Message to GrindEdit/Delete MessageReply w/QuoteDirect Link to This Post
After reading http://www.miataturbo.net/s...x-helical-lsd-56707/
I'd be willing to give OBX a try.
Grind
Report this Post11-06-2014 09:06 AM Click Here to See the Profile for GrindSend a Private Message to GrindEdit/Delete MessageReply w/QuoteDirect Link to This Post
Grind
