  sensor connectors
sensor connectors by newfiejeff
Started on: 11-02-2014 07:38 PM
Replies: 2 (146 views)
Last post by: phonedawgz on 11-03-2014 07:58 AM
newfiejeff
Report this Post11-02-2014 07:38 PM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
1986 2m4
Anyone got the part numbers for the sensor connectors on the 86 Fiero? Example, MAP, engine coolant, etc
Bloozberry
Total ratings: 311
Report this Post11-03-2014 06:51 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by Bloozberry (edited 11-03-2014).]
Total ratings: 290
Report this Post11-03-2014 07:58 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's a start - http://www.picowiring.com/pdf/Cat-36-40.pdf http://www.picowiring.com/pdf/Cat-31.pdf http://www.picowiring.com/catalog.html
While the catalog lists the Pico parts numbers they also include the GM/Delphi/Delco part numbers
Note - on Weatherpack connectors - the connectors are keyed by cuts in the barrel. Don't assume that a 3 pin Weatherpack connector will fit just because it has 3 pins. The latches also change at times.
GM 12117385 - O2 sensor
Delco PT308 - Fan Switch
GM 12101903 - A/C Compressor - But you must add the diode
GM 12101899 - CTS
GM 12102620 - IAT/MAT
GM 88860464 - Black side of the coil
GM 12101896 - Gray side of the coil
GM 12085502 - MAP
GM 12085506 - IAC
GM 12126487 - 4 Wire Distributor
GM 12101899 - 2 Wire Distributor
GM 12015792 - Shell only - VSS when loaded with Male Weatherpack Pins
GM 12015792 - Shell only - 5 Speed Reverse Switch when loaded with Female Weatherpack Pins
Note - these are the pigtail part numbers. The connectors also are sold as shell and terminal/seals. They then have different part numbers.
[This message has been edited by phonedawgz (edited 11-03-2014).]
