Update System
  The Spec Stage 3 clutch on Amazon
by RotrexFiero
Started on: 11-01-2014 06:51 PM
Replies: 8 (766 views)
Last post by: Raydar on 12-12-2014 07:08 PM
RotrexFiero
Report this Post Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is this the correct clutch for the Getrag 5 speed, and 3800 SC? Can it handle the torque?
Here it is:
http://www.amazon.com/URSC7...eywords=fiero+clutch
AutoMarshal
Report this Post Click Here to See the Profile for AutoMarshalClick Here to visit AutoMarshal's HomePageSend a Private Message to AutoMarshalEdit/Delete MessageReply w/QuoteDirect Link to This Post
1fast2m4
Report this Post Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
You don't want a just the stage 3. The stage 3 has a VERY aggressive engagement and tends to chatter. The 3+ is much better because the disc is a continuous design.
you can see the differences in the stages in this pic.
1986 SE 3800SC/4t65eHD (12.871@104.96)
HX-40, FrozenBoost I/C, 80lb injectors & E85 Coming soon.....
1fast2m4
get the part #'s off here then search for the part number on amazon
3800 + 4 speed
http://www.specclutch.com/c...rsion_combos/view/10
3800 + 5 speed
http://www.specclutch.com/conversion_combos/view/9
cyrus88
Report this Post Click Here to See the Profile for cyrus88Send a Private Message to cyrus88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have the stage 3 and I don't have any problem with chatter in my V8 swap. It's pretty smooth.
hnthomps
Total ratings: 50
Report this Post Click Here to See the Profile for hnthompsClick Here to Email hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have SPEC Stage 3+ on a more or less stock 3800 SC Series II (3.4 pulley and around 258 hp/300 ft lbs torque at the wheels) and it is delightful to drive. I also use a SPEC Stage 2 clutch on a turbo 3.4 engine and it is very smooth but this car is likely a bit less hp than the 3800 SC engine. So far my experience with a SPEC clutch has been very good.
Nelson
[This message has been edited by hnthomps (edited 11-02-2014).]
RotrexFiero
The spec 3+ it is then. Thanks for all the information and help.
Mr. Farknocker
Report this Post Click Here to See the Profile for Mr. FarknockerClick Here to Email Mr. FarknockerSend a Private Message to Mr. FarknockerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you bite the bullet and buy one?
Farknocker's Superfly Yellow '87 GT
355ci Chevy
....chicks dig it, men fear it.
Total ratings: 465
Report this Post Click Here to See the Profile for RaydarClick Here to Email RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a Stage 2 in my 3.4 car. It chattered when it was cold and slipped when it was hot.
Probably won't be doing that again.
