  heat extraction (front)
heat extraction (front) by jediperk
Started on: 10-31-2014 08:11 PM
Replies: 3 (222 views)
Last post by: Arns85GT on 11-01-2014 01:24 PM
jediperk
Report this Post10-31-2014 08:11 PM Click Here to See the Profile for jediperkSend a Private Message to jediperkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm pretty sure there is a thread around here somewhere that explains how to extract the hot air from behind the radiator without using heat extractors in the hood. Can one of you kind fellows help me find this thread?
Thanks!
dobey
Total ratings: 371
Report this Post10-31-2014 08:48 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure where the thread is, but I think this is what you're looking for: http://fierosound.com/moreM...iator%20Area%20Vents
jediperk
Report this Post10-31-2014 08:54 PM Click Here to See the Profile for jediperkSend a Private Message to jediperkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Y'up, that is what I was looking for and what I was kind of envisioning in my minds eye. Thanks for the info
Arns85GT
Total ratings: 202
Report this Post11-01-2014 01:24 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just about did the same thing, however I figured out that the air also has to pass through the fender liner. I ended up drilling 1/4" weeping holes in the floor of the cavity. I drilled about 25 of them in an X pattern so as not to weaken the panel. It worked fine.
