  cadillac 4.1
cadillac 4.1 by tooldoc
Started on: 10-31-2014 08:31 AM
Replies: 5 (572 views)
Last post by: Arns85GT on 10-31-2014 09:30 PM
tooldoc
Report this Post10-31-2014 08:31 AM Click Here to See the Profile for tooldocSend a Private Message to tooldocEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is it possible to run a 4.1 with an hei and no computer I put a edelbrock carb on it but cannot get it to run
Report this Post10-31-2014 08:36 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Run screaming from your HT4100.......not a good motor to put any effort or $$$ into.
Report this Post10-31-2014 10:18 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 4.1L Cadillac engine was an early 1980's design. If they were meticulously maintained and never overheated the slightest bit they ran fine but throughout its history it was plagued by leaking cylinder head gaskets that would cause antifreeze to get into the oil that destroyed the bearings.
If you are dead set in using this engine in a Fiero, a non ECM distributor, carburetor and new fuel pump/reg would be required to convert it to non-ECM use. That engine is now very old and 35 years later I would not expect much.
jimbolaya
Total ratings: 114
Report this Post10-31-2014 10:36 AM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good news is the transmission would probably work with it. LOL Long story, and I'm still a little bitter.
Jim
Lou6t4gto
Report this Post10-31-2014 01:21 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
4100, was the worst engine caddy ever let escape, Don't put any $$ into it
Arns85GT
Total ratings: 202
Report this Post10-31-2014 09:30 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The carb can be done fairly easily.
https://www.fiero.nl/forum/F...2/HTML/127788-2.html
You really want to be careful on measuring when you cut the stem on the Olds guts. It has to be exactly the right length or the cam will chew up the gear
Arn
