  Brake booster to front firewall seal question
Brake booster to front firewall seal question by Daleford
Started on: 10-30-2014 06:19 PM
Replies: 6 (396 views)
Last post by: sardonyx247 on 11-04-2014 10:37 PM
Daleford
Report this Post10-30-2014 06:19 PM Click Here to See the Profile for DalefordSend a Private Message to DalefordEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am finishing up an 86 Fiero chassis for my kitcar. I just noticed the white plastic seal at the rear of the brake booster is cracked. It apparently is the seal to the firewall that snaps into place. Can this part be bought separately? Has anyone simply silicone it over?
Daleford
Report this Post11-02-2014 07:38 PM Click Here to See the Profile for DalefordSend a Private Message to DalefordEdit/Delete MessageReply w/QuoteDirect Link to This Post
Never got an answer to this........
Again, this white plastic piece appears to be what seals the water from getting through the firewall, just to the rear of the brake booster. Can I buy that part?
seajai
Total ratings: 52
Report this Post11-03-2014 12:19 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
That booster was only used on the Fiero so I doubt your going to find a new extension tube. The Fiero parts book doesn't even show it as a part you could have purchased. You're going to have to fix the one you have or find a Fiero in a junkyard to get the part.
Arns85GT
Total ratings: 202
Report this Post11-03-2014 08:05 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do the $100 upgrade to the S10 booster. You'll like it allot
sardonyx247
Total ratings: 219
Report this Post11-04-2014 04:31 PM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
[This message has been edited by sardonyx247 (edited 11-04-2014).]
Daleford
Report this Post11-04-2014 09:00 PM Click Here to See the Profile for DalefordSend a Private Message to DalefordEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by sardonyx247:
PM sent.
Thanks for the message but the form won't let me reply to you. Here is my message back:
sardonyx247 Thanks for the message. Not sure on this one. hate disconnecting brake lines to install it.
Will look at mine again and consider THANKS
sardonyx247
Total ratings: 219
Report this Post11-04-2014 10:37 PM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just fyi, you don't have to disconnect the brake lines to remove the booster, you unbolt the master from the booster and move it forward with the lines attached. Then the booster comes right out. Trust me, I have probably removed more boosters than anyone on here.
