  Radio weird problems
Radio weird problems by newfiejeff
Started on: 10-21-2014 07:57 PM
Replies: 4 (191 views)
Last post by: imabaddude on 10-21-2014 08:11 PM
newfiejeff
Report this Post10-21-2014 07:57 PM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey, since I bought the car last fall the radio hasn't worked or worked very well.
Problems
Won't store channels or will store channels while the car is going and will lose them when the car is turned off
The clock always starts at 0:50 for the time and then will count going up while driving.
The radio station takes a while to pick up the channel, you might have to drive 15 mins or more before tuning in and when it does all known good channels will not work only some.
Is the radio garbage(right now it is..lol)?
imabaddude
Report this Post10-21-2014 08:03 PM Click Here to See the Profile for imabaddudeSend a Private Message to imabaddudeEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have two power sources for radios, the constant, which keeps your presets on clock set, and then the one that supplies power only when the car is on or you have it in ACC mode, and that is the one that turns on your radio. Someone just posted the Fiero stock wiring diagram for the radio, and on most aftermarket stereos yellow is the constant, and Red is the ACC.
imabaddude
Report this Post10-21-2014 08:04 PM Click Here to See the Profile for imabaddudeSend a Private Message to imabaddudeEdit/Delete MessageReply w/QuoteDirect Link to This Post
imabaddude
Member since Sep 2012
Originally posted by IMSA GT:
You're using a 12 volt probe light at the speaker terminals and GETTING 12 volts out of the wiring? I've never heard of that but then I have never tried that.
Did you use an adapter harness for the Fiero or just cut off the factory connector, meter the wiring and hooked it up that way?
This is from AndyLPhoto on here:
Be aware that some people have had issues with the taillight fuses blowing if you connect the gray (panel illumination) or brown (dim signal) wires so be careful.
newfiejeff
Report this Post10-21-2014 08:04 PM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its the original radio
imabaddude
Report this Post10-21-2014 08:11 PM Click Here to See the Profile for imabaddudeSend a Private Message to imabaddudeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pull it out and check the wiring. It may have been removed and an aftermarket one put in, and then lazily put the stock one in to sell it.
