  mystic teal paint
mystic teal paint by majest12
Started on: 10-21-2014 11:21 AM
Replies: 19 (617 views)
Last post by: majest12 on 11-08-2014 12:39 PM
majest12
Report this Post10-21-2014 11:21 AM Click Here to See the Profile for majest12Send a Private Message to majest12Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone else have a stock 1984 SE Fiero in factory mystic teal?
jaskispyder
Total ratings: 205
Report this Post10-21-2014 11:40 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hmmm, you could try "google images" to search for teal fiero. That may help narrow it down if you are looking for repainted fieros.
Just to be clear, there were no factory teal cars. Blue was the closest and that was in '87 (except for a few test versions released earlier).
If you look in the front compartment, there should be a plate/sticker with a paint code at the bottom. Something like "WA-4565".... This is the paint code.
And a link to the 1985 Factory blue coupe...
https://www.fiero.nl/forum/Forum1/HTML/090696.html
[This message has been edited by jaskispyder (edited 10-21-2014).]
Report this Post10-21-2014 11:41 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the Fourm! Have you figured out how to post pictures?
majest12
Report this Post11-07-2014 03:53 AM Click Here to See the Profile for majest12Send a Private Message to majest12Edit/Delete MessageReply w/QuoteDirect Link to This Post
It appears factory original. Did some searching and it's a Pontiac paint but said to only be used on the Firebird. Some searches mentioned that dealerships could special order them for picky customers in any Pontiac color...true?
majest12
Report this Post11-07-2014 04:04 AM Click Here to See the Profile for majest12Send a Private Message to majest12Edit/Delete MessageReply w/QuoteDirect Link to This Post
majest12
Member since Oct 2014
It's the Fiero I just bought, and it seems to have original paint...but I've never seen this color on the Fiero. I actually had the Firebird in this color.
[This message has been edited by majest12 (edited 11-07-2014).]
majest12
Report this Post11-07-2014 04:35 AM Click Here to See the Profile for majest12Send a Private Message to majest12Edit/Delete MessageReply w/QuoteDirect Link to This Post
majest12
Indyellowgt
Total ratings: 70
Report this Post11-07-2014 07:41 AM Click Here to See the Profile for IndyellowgtSend a Private Message to IndyellowgtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice looking '84 :-)
I would take jaski's info and seek out the paint code on the RPO tag under the front hood.
If the car had at any time had a quality paint job,all the body panels were probably removed,shot,then reassembled..hence the 'factory' look .
Its not a possibility that GM painted the cars for a dealer.. GM was running only 4 paint colors for the 84's. Black,red,silver,white. The earliest Fieros were only red and white.
Unless a dealer painted the cars themselves,I think you've got a previous owner repaint at some time.
Mark
jaskispyder
Total ratings: 205
Report this Post11-07-2014 08:03 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are the mirrors and front bumper pads the same color as the body? If so, pretty good evidence of a repaint. I would take a really close look at the panels and also tell us the color from the RPO sticker.
Personally, there is no way I can see this being a "factory" color, unless it was something GM pulled from the line and painted it to test the color. It wouldn't have been a factory color, as stated, because of the number of paint lines available.
Just to add a dealer could have repainted it for a picky customer.
[This message has been edited by jaskispyder (edited 11-07-2014).]
rogergarrison
Total ratings: 551
Report this Post11-07-2014 10:10 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
This sticker should be on top of the drivers side fenderwell and easily seen. BTW this pic of it shows WA 8554 which is white, not teal, just to avoid confusion.
You USED to be able to order cars just about any color, even a different brand for additional cost. They stopped that I believe in the late 70s. I ordered a new Mustang to be painted a specific color, they took the payment. They did however cancel the paint and refund the money saying they didnt do that anymore and I had to select an OEM color. There are select companies that still can because they buy in bulk. Mary Kaye Pink is an example of that. All those pink Caddys come from the factory that color.
TONY_C
Report this Post11-07-2014 12:52 PM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't tell from the pics but it looks like the bumper pads are painted in teal and not black. Are they black? What about the decklid vent and covers and the panels surrounding the rear window? Are they black?
rogergarrison
Total ratings: 551
Report this Post11-07-2014 02:12 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
They look black to me. If your RPO tag confirms your color is teal, you have a very rare car. Id check with the Pontiac Historical Society if it is to see if they have any info on it. It could have been done for a Pontiac exec or something.
jaskispyder
Total ratings: 205
Report this Post11-07-2014 02:23 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
better pic. bumper pads are black, mirror is green.
http://i1178.photobucket.co..._20140923_183556.jpg
TONY_C
Report this Post11-07-2014 03:02 PM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would think the green mirror is the giveaway that it is not factory paint since all the mirrors were black regardless of color.
jaskispyder
Total ratings: 205
Report this Post11-07-2014 03:14 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, BUT, those could have been painted afterwards. I had my mirrors painted to match. But again, I can't see where this is factory, based on what we know about the factory equipment. RPO tag will solve the question.
majest12
Report this Post11-08-2014 12:54 AM Click Here to See the Profile for majest12Send a Private Message to majest12Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bad pic, try for a better one in the morning
[This message has been edited by majest12 (edited 11-08-2014).]
majest12
Report this Post11-08-2014 01:02 AM Click Here to See the Profile for majest12Send a Private Message to majest12Edit/Delete MessageReply w/QuoteDirect Link to This Post
majest12
http://rs1178.pbsrc.com/alb...7_224514.jpg~320x480
Straight to photo bucket...readable
majest12
Report this Post11-08-2014 01:21 AM Click Here to See the Profile for majest12Send a Private Message to majest12Edit/Delete MessageReply w/QuoteDirect Link to This Post
majest12
Lol...wait...it was white huh? Lmao
majest12
Report this Post11-08-2014 01:23 AM Click Here to See the Profile for majest12Send a Private Message to majest12Edit/Delete MessageReply w/QuoteDirect Link to This Post
majest12
I think that covers it...you guys are AWESOME! I love my Fiero!
rogergarrison
Total ratings: 551
Report this Post11-08-2014 10:10 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yours is hard to read...to me it looks like the original paint was W 8555 which was black. Someone has later repainted it the teal and had the courtesy to mark it down for you. Whether it was done by someone themself or a dealer isnt apparent. If it came out of the factory, they would have had the correct WA number on it originally...dont think they would have written it on with a marker. If you research the VIN number (you can call the dealer parts department and ask for the color by the VIN) you will find out what it rolled out the door as...my guess is 8555 black. As an added note, some of the cars also have a VIN PLATE that is riveted on under the front hood somewhere like firewall or core support. It will have a 2 digit number followed by a U or L. That is also a code for the color. (ie/ 11U)
majest12
Report this Post11-08-2014 12:39 PM Click Here to See the Profile for majest12Send a Private Message to majest12Edit/Delete MessageReply w/QuoteDirect Link to This Post
Pretty sure it was repainted. This is my first Fiero, thank you guys for the info ...ps..what's up with the the two different sizes tires?! Lol...I'm gonna just wrap it in the 205/15 50R tires that are on the rear. No biggie right?
