| quote | Originally posted by jraul:
Well I appreciate it I don't know where to start since this would be the first swap I do I'm kind of lost I have pretty good mechanic skills so doing the labor part bis easy it's just finding the information that's hard especially looking for a kit |
First decided if your going to make your own brackets and harness. If your going to buy them its an extremely easy swap. I bought my harness and brackets from fieroflyer (only makes harnesses now someone else does the brackets)
http://www.fiero.nl/forum/Forum4/HTML/064839.html. I bought the modified axle from mstangsBware
http://www.fiero.nl/forum/Forum4/HTML/065499.html. Get your engine mount it to your cradle, attach your harness, install your axles, and the bulk of it is done. You will need to make or buy a modified dogbone mount, depending on what year fiero tap the lower intake manifold to add a line for heater, get a modified thermostat housing for the other heater line, plug the whole on the water pump with a freeze plug, make an exhaust, mount your computer (Dan will build the harness so the computer can go where you want it) and some other odds and ends but it all comes together easy enough. This is just the way I did it there are other ways. good luck with your swap
