  Stalling in reverse.
Stalling in reverse. by un fiero
Started on: 10-18-2014 04:41 PM
Replies: 15 (336 views)
Last post by: un fiero on 10-21-2014 10:06 PM
un fiero
Report this Post10-18-2014 04:41 PM Click Here to See the Profile for un fieroSend a Private Message to un fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
88 2.5 automatic has started to stall when going into reverse. When I come to a stop, put it in reverse as soon as I release the brake, it stalls. Maybe something electrical? Any help would be appreciated.
Report this Post10-19-2014 10:54 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
bump it up....can't help with automatics...
Total ratings: 290
Report this Post10-19-2014 02:10 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shoot a video - include the tach in the video and sound when it stalls and post it somewhere. Then link to it on here.
Report this Post10-19-2014 05:13 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have enough gas in the tank? Maybe the gas is sloshing towards the front of the tank leaving the fuel pump pick-up exposed? Just a guess!
Try going into reverse on a steep hill with the nose facing uphill and see if it makes any difference.
[This message has been edited by Patrick (edited 10-20-2014).]
DKcustoms
Report this Post10-19-2014 05:14 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you tried giving it gas before you release the brake to keep the revs up?
Does it stutter at all or just die immediately?
un fiero
Report this Post10-20-2014 08:48 PM Click Here to See the Profile for un fieroSend a Private Message to un fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the replies, but I believe its the tcc switch in the tranny. I unplugged it and I have driven it four times. A lot of start and stop, and reverse and drive and it has not done it at all. I don't feel any difference driving it this way and its only a toy not a daily driver so when I get motivated, I'll change it out. Doesn't look fun!
Report this Post10-20-2014 08:58 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't understand why putting the tranny into "Reverse" (and releasing the brake) would've had anything to do with the problem you were describing.
Seems to me that if the TCC wasn't releasing that the engine would've stalled just by stopping the car while still in "Drive".
un fiero
Report this Post10-20-2014 09:45 PM Click Here to See the Profile for un fieroSend a Private Message to un fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Patrick, you are absolutely right. About 2 weeks ago it happened about two blocks from the house as I came to a stop. It would start just fine, and I could put it in drive and as soon as I let off the brake it would shudder and die. It did it that night four or five times before I was able to drive off. I may still have a problem but it just hasn't surfaced. I guess we'll see.
Report this Post10-20-2014 09:56 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, you'll still have a "problem" until you replace the TCC solenoid, but with it disconnected you'll at least be able to drive the car. Gas mileage will suffer on the highway, but around town it'll hardly be noticeable.
Alex.07.86GT
Report this Post10-20-2014 09:56 PM Click Here to See the Profile for Alex.07.86GTSend a Private Message to Alex.07.86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I dont know about your fix, but you should have a Mech adjust your reverse band. and do check your trans filter & fluid level. also check the quality of your trans fluid.
un fiero
Report this Post10-20-2014 11:15 PM Click Here to See the Profile for un fieroSend a Private Message to un fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
If I start to drive it more, I'll probably fix it. If not, I'm just gonna wait till I can ship it up to Michigan to have a 3800sc swap.
Alex.07.86GT
Report this Post10-20-2014 11:33 PM Click Here to See the Profile for Alex.07.86GTSend a Private Message to Alex.07.86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
that would be a good time to get the trans rebuilt or relaced
Lou6t4gto
Report this Post10-21-2014 01:14 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
had a Pontiac once that when you put it in reverse it stalled (automatic) thing was: when put in reverse, the engine "torqued" a little bit, just enough to move the engine so as a bare wire shorted out every time it moved. maybe.....
Total ratings: 290
Report this Post10-21-2014 10:20 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your TCC is working correctly*. It is your ECM or wiring is what is failing.
When the TCC fails, it stays locked up. When you release your brake pedal, your TCC is locking up and stalling the engine. That means the TCC is actually working. The brake switch keeps power off of the TCC circuit when depressed. It supplies power only when the brake switch is in the rest position. On the other side of the TCC solenoid the ECM grounds the circuit to activate. So somehow the negative side of your TCC solenoid is getting grounded.
The possibilities - ECM, TCC to ECM wiring, or perhaps by chance the short to ground could be in the TCC itself*.
[This message has been edited by phonedawgz (edited 10-21-2014).]
Lou6t4gto
Report this Post10-21-2014 08:53 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unplug the torque converter lockup Switch and find out. BUT, ( I would think IF that was the problem it would also do it in drive)
un fiero
Report this Post10-21-2014 10:06 PM Click Here to See the Profile for un fieroSend a Private Message to un fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
IThe first time it happened, it was in drive. It took at least four or five tries before it let me drive off. The last time it did it, I came to a stop in front of my driveway, and when I shifted into reverse ( and released the brake) it stalled. I never put it back in drive once I got it in the driveway. Anyway, I've driven it a few times with the tcc unplugged and it hasn't done it since.
