  HE341W on a LQ1?
HE341W on a LQ1? by hookdonspeed
Started on: 10-16-2014 03:38 PM
Replies: 14 (446 views)
Last post by: darkhorizon on 10-21-2014 10:20 AM
hookdonspeed
Total ratings: 131
Report this Post10-16-2014 03:38 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
would it be a good fit or no? im awful at reading compressor maps.
hookdonspeed
Total ratings: 131
Report this Post10-16-2014 03:46 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
suppose to be the same as a hy35
Report this Post10-16-2014 05:00 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
It all depends on how much power you are looking to make.
hookdonspeed
Total ratings: 131
Report this Post10-16-2014 05:03 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is alot but not too much a proper answer?
350-400 would be nice
Justinbart
Total ratings: 119
Report this Post10-16-2014 05:28 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
It should work. Its hard to go wrong with a turbo really unless you are trying to fit in some kind of limited class.
Turbo 3800 E85 F23 5spd spec5
10.91@133.1
darkhorizon
Total ratings: 451
Report this Post10-16-2014 06:34 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMO I would look into a smaller ebay turbo. The newer holsets are really more suited for the 500hp range.
hookdonspeed
Total ratings: 131
Report this Post10-16-2014 09:04 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
any ideas where the LQ1 would fall on that map?
and i though the HY35 is smaller then the HX?
darkhorizon
Total ratings: 451
Report this Post10-17-2014 10:33 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
341 is a bigger turbo than a hx35 without issue. The exhaust housing is setup for a bit faster spool but on a gas motor it wont hurt your power much. I wouldnt expect less than 500whp out of one on good fuel.
hookdonspeed
Total ratings: 131
Report this Post10-17-2014 11:44 AM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hrm..... Wonder if the lq1 can handle 500hp...
darkhorizon
Total ratings: 451
Report this Post10-17-2014 03:12 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
depends what rods you put in it. Stock rods I would cross your fingers at 275whp.
Report this Post10-17-2014 06:23 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try to track down Matt Hawkins. He was a member here not long ago that built a turbo 3.4L TDC engine. Matt claimed his engine generated 400+ HP. AFAIK, Matt's engine remarkably stayed together at that power level but he blew up a few GETRAGS. This was before the F23 became popular.
Fierobsessed
Total ratings: 147
Report this Post10-18-2014 02:19 AM Click Here to See the Profile for FierobsessedSend a Private Message to FierobsessedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cross posted from a thread less relevant:
I'm going to assume you mean HY35W Type D. The compressor numbers look good, not all that different than a GT3582R like I'm running, which is more or less ideal. Overall, its just a touch smaller than the GT3582R. But that means its drivability will be very good.
I'd opt for an A/R ratio on the turbine housing in the .8 ish range. Otherwise you'll start to cut into how much power you could make, and if you go into the 1.XX range, it'll be a little slower spooling, but get better at full boost. .8 A/R will get you great road manners and spool pretty quickly.
The only reason on saying you probably mean the HY35, is because the HE341 is actually very hard to come by and VERY expensive. Most people have a HY35W Type D and mistake it for a HE341 because the discharge is front facing. Most people sell them claiming they are HE341's. At least, that's what I read.
Rods seem to be good up to 400, maybe 450 ish, but this is coming from a guy that just broke an undetermined bottom end part, probably in the mid 400's horsepower on a 3.4 DOHC. I'll devulge the damage when I get to it.
JohnSmith
Report this Post10-18-2014 05:18 AM Click Here to See the Profile for JohnSmithSend a Private Message to JohnSmithEdit/Delete MessageReply w/QuoteDirect Link to This Post
Aren't there several LQ1 turbos running at over 400qhp reliably right now? That was rhetorical, there are. No one really knows the limit of the 3.4 bottom end.
hookdonspeed
Total ratings: 131
Report this Post10-20-2014 06:02 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes, a good amount it seems.
darkhorizon
Total ratings: 451
Report this Post10-21-2014 10:20 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
There may be. I guess there is only one way to find out.
