  How do keep the waterpump from turning when reinsatlling?
How do keep the waterpump from turning when reinsatlling? by Madess
Started on: 10-16-2014 11:33 AM
Replies: 4 (126 views)
Last post by: Lou6t4gto on 10-16-2014 01:42 PM
Madess
Report this Post10-16-2014 11:33 AM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
How do you keep the water pump from turning when reinstalling the the pulley bolts? Dumb question I know, but I know there has to be a simple solution.
Total ratings: 236
Report this Post10-16-2014 11:43 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Run them all down sung, then put the belt on and tension the belt before torquing the bolts.
ignorant prodigy
Report this Post10-16-2014 12:03 PM Click Here to See the Profile for ignorant prodigySend a Private Message to ignorant prodigyEdit/Delete MessageReply w/QuoteDirect Link to This Post
They make strap wrenches that let you hold the pulley in place.
sears has them for cheap.
you can also check amazon
http://www.amazon.com/Wilma...keywords=belt+wrench
Lambo nut
Total ratings: 257
Report this Post10-16-2014 01:39 PM Click Here to See the Profile for Lambo nutSend a Private Message to Lambo nutEdit/Delete MessageReply w/QuoteDirect Link to This Post
^ That's the way I do it. Can use the belt itself as a make shift strap wrench at times if need to.
Kevin
Lou6t4gto
Report this Post10-16-2014 01:42 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hit 'em with the air wrench.
