  Can I use my cruse control box from my parted truck?
Can I use my cruse control box from my parted truck? by Tweeder
Started on: 10-15-2014 12:27 AM
Replies: 2 (102 views)
Last post by: 85 SE VIN 9 on 10-15-2014 10:33 AM
Tweeder
Report this Post10-15-2014 12:27 AM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the black box and cable which goes to the throttle off my 2000 silverado. My car has the cruise on the turn thingy.
86 SE Convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
Total ratings: 290
Report this Post10-15-2014 01:47 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Give it a try. All the cruise boxes wire the same so idk what the differences are between them. If nothing else all you will need to swap is the servo itself if it isn't compatible.
85 SE VIN 9
Report this Post10-15-2014 10:33 AM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Um, not to hijack, but I bought the TFS vacuum can and hoses and hooked up my cruise on 85 GT, but nothing happened. Everything seems to be there, including switches on clutch and brake, the servo, cable, dump valve, and connectors. All fuses seem to be present and good, but which one is for cruise? I haven't found a wiring diagram that mentions cruise. I'm wondering if cable is properly connected to throttle. How do you check this thing given it's not supposed to work until you're over 25 mph?
