  Seatbelts don't lock?
Seatbelts don't lock? by tom10122
Started on: 10-14-2014 08:09 PM
Replies: 4 (324 views)
Last post by: tom10122 on 10-15-2014 04:21 PM
tom10122
Report this Post10-14-2014 08:09 PM Click Here to See the Profile for tom10122Send a Private Message to tom10122Edit/Delete MessageReply w/QuoteDirect Link to This Post
My seatbelts don't lock up when jerked forward or out. Seems like they wouldn't do much in an accident, is there something wrong or is that just how it is?
Stubby79
Total ratings: 58
Report this Post10-14-2014 10:03 PM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
Normal. They don't use centrifugal force like normal seat belts to lock. They use....forward decelleration force(if that's the term) to lock. Slam on your brakes hard enough when moving fast enough and you'll lock them.
jaskispyder
Total ratings: 205
Report this Post10-15-2014 09:47 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup, there is a weight inside the mechanism.
Report this Post10-15-2014 02:58 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Actually there's two weights, one for each belt, and lock for fast deceleration in any direction. GM and others use same method for many years.
If you clean the lock... Do Not lube them! Lube can help short term but is worse.
Lube will attract and hold dirt, get on the belt and stain your clothes, and lube can make the belt weaker then the belt would fail in a crash.
tom10122
Report this Post10-15-2014 04:21 PM Click Here to See the Profile for tom10122Send a Private Message to tom10122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys I appreciate the information.
