  3800sc wont idle after alternator was replaced
3800sc wont idle after alternator was replaced by Fadingaway
Started on: 10-14-2014 01:05 AM
Replies: 4 (143 views)
Last post by: GODFATHER on 10-15-2014 09:17 AM
Fadingaway
Report this Post10-14-2014 01:05 AM Click Here to See the Profile for FadingawaySend a Private Message to FadingawayEdit/Delete MessageReply w/QuoteDirect Link to This Post
my alternator died out last night and i drove her home on battery power, i swapped out the alternator with a fresh reman from autozone and she will fire but wont run unless i throttle it then she chokes out and dies ive checked all of my vacuum lines sensors and plugs everything seems in order fuel pressure is good and i clearly have spark, what am i missing?
Report this Post10-14-2014 08:04 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Report this Post10-14-2014 09:31 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check alternator output. It should be around 14V when the engine is first started and then settle down to a bit over 12V in 15 minutes or so of driving.
Total ratings: 290
Report this Post10-15-2014 01:45 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pull out your IAC. Retract the spring and screw the pintle in several turns. Replace it and see what happens.
GODFATHER
Report this Post10-15-2014 09:17 AM Click Here to See the Profile for GODFATHERSend a Private Message to GODFATHEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Try cleaning out your throttle body and what phonedawgz said also. When battery is disconnected computer might have to go thru a relearn.
