  misc cradle drop questions, putin' it back together thread
misc cradle drop questions, putin' it back together thread by ZaraSpOOk
Started on: 10-13-2014 08:48 PM
Replies: 3 (191 views)
Last post by: ZaraSpOOk on 10-15-2014 08:47 PM
ZaraSpOOk
Report this Post10-13-2014 08:48 PM Click Here to See the Profile for ZaraSpOOkSend a Private Message to ZaraSpOOkEdit/Delete MessageReply w/QuoteDirect Link to This Post
if anyone has a picture or can describe the way the lower tranny cable, the one to outside of car is supposed to be, it would be appreciated. I am talking from firewall to tranny. Second time doing this, should have taken a picture, thought I knew what I was doing. Here is how it is now. the lower one, how should that be routed, doesn't seem right(you can't see it in the picture, it is comes from under but is hitting the exhaust..
that thingamajig just to the right of upper cable, if the picture was better you could easily tell the vacuum line is broken, will car run without it? I can jury rig it, obviously I need a long term solution, but I'm wondering how important.
also you can't see it but the thingamajig on the exhaust, the connector broke, what is it, do I need it, where can I find another?
thingamajig= I bet you're wondering "this guy did a cradle drop, doesn't sound like he can find the dip stick"
I was just laid off, and am mentally exhausted cause I worked my but off to get something done right, and this was my reward. Doesn't seem right, but whatcha gonna do?
work on a car, that's what
[This message has been edited by ZaraSpOOk (edited 10-13-2014).]
gen2muchwork
Report this Post10-14-2014 06:36 AM Click Here to See the Profile for gen2muchworkSend a Private Message to gen2muchworkEdit/Delete MessageReply w/QuoteDirect Link to This Post
the vac. line is the egr line. plastic line can be repaired with hose. Bad news, the egr tube appears broken (flexible metal part) I've not had to replace one, but it does not seem like a fun job. think rodney? sells one. maybe TFS too. there are a lot of members who have replaced a broken egr tube here. You will have problems if you don't fix it. start spraying the pb blaster.
fierosound
Total ratings: 286
Report this Post10-14-2014 08:34 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't see your pic at work. My work computer blocks photobucket etc. but sounds like a Getrag 5-speed?
This is the revised cable routing for the Getrag transmission
http://www.meisners.net/fiero/TSB/TSB88714.htm
Calgary time/temp
ZaraSpOOk
Report this Post10-15-2014 08:47 PM Click Here to See the Profile for ZaraSpOOkSend a Private Message to ZaraSpOOkEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks, I kind of thought the cable is supposed to go behind the heat shield, I'll change it tomorrow
and thanks for the tip on EGR
