  Replacing the stock Radiator fan. Mine is broke.
Replacing the stock Radiator fan. Mine is broke. by RyanFrisk8
Started on: 10-13-2014 12:12 AM
Replies: 5 (217 views)
Last post by: RyanFrisk8 on 10-13-2014 10:07 AM
RyanFrisk8
Report this Post10-13-2014 12:12 AM Click Here to See the Profile for RyanFrisk8Send a Private Message to RyanFrisk8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I bought an 86 Fiero SE 2.8L V6 last year as a project car and I am just getting around to finish it. The Radiator fan that it came with is broken and I was wondering what the best route to go would be.
-Should I buy an aftermarket one and put it in or do you think one out of a different car has more pulling/pushing power?
-And secondly, I was wondering if there are any fans in other cars that will mount and work good so I can just go to the junkyard and pull that part..
James Bond 007
Total ratings: 263
Report this Post10-13-2014 12:26 AM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wellcome to the forum.You can buy and replace the motor or is it more to it? Check your fan relay, the fan should turn on with the ac, let us know if it kicks on.
RyanFrisk8
Report this Post10-13-2014 12:29 AM Click Here to See the Profile for RyanFrisk8Send a Private Message to RyanFrisk8Edit/Delete MessageReply w/QuoteDirect Link to This Post
The motor is toast and for the cost of replacing the motor I figured I could get a new fan from the junkyard out of another type of vehicle.
Report this Post10-13-2014 12:36 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
acdelco.com
look up fan motor
find that and read x models used this motor.
J Gunsett
Report this Post10-13-2014 07:50 AM Click Here to See the Profile for J GunsettClick Here to visit J Gunsett's HomePageSend a Private Message to J GunsettEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you want a good upgrade for your fan and car take a look at this thread:
https://www.fiero.nl/forum/F...124791.html#lastpost
About half way down it shows a fan upgrade that I think is one of the best.
If we can help here please ask away.
Jack
RyanFrisk8
Report this Post10-13-2014 10:07 AM Click Here to See the Profile for RyanFrisk8Send a Private Message to RyanFrisk8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Jack. That's what I was looking for.
