  2.8-3.4L engine sources??
2.8-3.4L engine sources?? by fierogt28
Started on: 10-12-2014 11:30 PM
Replies: 15 (597 views)
Last post by: sardonyx247 on 10-16-2014 04:41 AM
fierogt28
Report this Post10-12-2014 11:30 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Where are folks getting their new 93-95 Camaro / Firebird 3.4L V6 engines??
I know the new 2.8L V6 aren't available anymore; just rebuilt, but since the fiero heads on a 2.8L
is the same as the 3.4L Camaro / Firebird engines, where can we get these new heads??
GM part # 14054884
TIA,
fierogt28
88 GT, Loaded, 5-speed.
hiwil88formula
Report this Post10-13-2014 12:34 AM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Junkyards. The s-10 upgrade is no longer available. At least I have not found one yet.
MarkS
Report this Post10-13-2014 06:26 AM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try this for junkyard searching:
http://www.car-part.com
BR's,
Mark
86 SE V6 4 speed
86 SE V6 Auto
2008 G6 GT "Street" Coupe
2005 Buick 3.6 Rendezvous
2001 Olds Silhouette (AKA The Band Van)
sardonyx247
Total ratings: 219
Report this Post10-14-2014 03:48 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Remaned heads usally can be found on E-Bay, there is a place in FL called oddessa cyl heads IIRC, they usally have a decent price on them.
Otherwise take your 2.8 heads to a machine shop and have them redo them. That is usally how it is done.
Edit to add:The way I found my 3.4 is I called EVERY junkyard in the phonebook, (yes a phonebook) call them ALL, and I mean ALL, I found a huge range of milage and prices, from $1500+ for 150,000 mile engine to $400 for a 50,000 mile one. Now we just get a good core and rebuild them.
"DRIVE IT LIKE A FIERO"
'87 Quad 4 H.O.
[This message has been edited by sardonyx247 (edited 10-14-2014).]
lou_dias
Report this Post10-14-2014 08:53 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
A better but more costly option is the 3400 block. You'll have to swap pistons but you won't have to drill starter holes and you get a free cam upgrade but need 1.6 roller rockers and 5.85" pushrods.
The stock 3400 roller cam offers .436/.436 lift with 1.6 roller rockers stock.
If you stick with 1.52 roller tips rockers over the Fiero's 1.5 It's still a mild cam upgrade, but those roller cams don't mind 1.6 rockers... Stock Fiero cam is .390/.410 w/1.5 ratio but roller cams ramp up quicker so the total area under the curve of lift is higher on a roller cam for the same lift.
[This message has been edited by lou_dias (edited 10-14-2014).]
Knight
Report this Post10-14-2014 01:38 PM Click Here to See the Profile for KnightSend a Private Message to KnightEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anybody got a complete parts list for the Fiero iron heads/3400 block hybrid build?
lou_dias
Report this Post10-14-2014 02:54 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can get 1.6 roller rockers from the Fiero Store.
5.85" pushrods from www.pushrods.net
You can use Camaro/Firebird pistons or go with the GM 3.4 TDOC motor's pistons for a higher compression ratio.
http://www.fierosound.com/34engine/3400details.htm
ignore the part about the pushrods being 3/8" diameter and machining the guides...
WOT-Tech has performance roller cams now, I just ordered the .490/.490 one myself...took 5 weeks to deliver.
fierogt28
Report this Post10-14-2014 08:29 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Does GM still have the 93-95 Camaro / Firebird available as crate engines??
Looking for a source for new parts...
fierogt28
zzzhuh
Report this Post10-15-2014 01:01 AM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
From what I understand, I guess they stopped making them . Really wish I could have gotten one before they stopped making them.
sardonyx247
Total ratings: 219
Report this Post10-15-2014 04:08 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Whats the problem with rebuilding a 3.4L ?
It's cheaper and you can use better parts.
Camel
Report this Post10-15-2014 06:37 AM Click Here to See the Profile for CamelClick Here to visit Camel's HomePageSend a Private Message to CamelEdit/Delete MessageReply w/QuoteDirect Link to This Post
+1
Crate Engines aren't superior to a professional rebuild.
Report this Post10-15-2014 09:36 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
www.groomsengines.com The engines used by Ed Parks at The Fiero Factory when he did 3.4 conversions. They won't void your warranty because you had starter mounting holes drilled on the other side of the engine. In fact, you may be able to get them to do it for you.
From their website:
The Only Engine Available
With a No Fault, No Hassle
Nationwide Lifetime Warranty
lou_dias
Report this Post10-15-2014 11:41 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jasper Engines also sells reman-ed engines.
Report this Post10-15-2014 02:19 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The last time I spoke with Jasper Engines, they wouldn't warrant an engine that had the starter boss redrilled or an engine used in applications other than what it was originally installed into. That was 4 or 5 years ago, at least. Might want to ask any engine reman company about that.
fierogt28
Report this Post10-16-2014 12:16 AM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is more the heads. Can you get new 14054884 cylinder heads.
If your valve guides are worn and are over spec, I guess you head is finished.
I never heard anyone replace the guides, unless there are sleeves available that I'm
not aware of.
Anyone??
fierogt28
sardonyx247
Total ratings: 219
Report this Post10-16-2014 04:41 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Valve guides can be pressed out and new ones pressed in. Any good machine shop should be able to do this.
They should even know where to get the guides, all part of head work.
[This message has been edited by sardonyx247 (edited 10-16-2014).]
